Computers & Internet Logo
Posted on Sep 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to become wireless - Computers & Internet
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Sep 19, 2008
Anonymous
Expert
Level 2:
Answers
84
Questions
0
Helped
28367
Points
238
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Wireless not working
Hi, Sometimes the wireless startup can become disabled. Try this to see if you can force your wireless connection to startup:
Start
Run
Type: "services.msc" (without quotes)
ok
Click: Wireless Zero Configuration
Click: "Start" (without quotes)
ok
Also, make sure that you have the most recent driver for your network adapter. Go to the manufacturer's website to check.
Good Luck!
Need help to install router, westell modem already installed
Turn off the modem (unplug it). Plug the eithernet wire into the router and into the modem. Turn on the modem - when lights become stable, turn on the router. - when the lights become stable, turn on your wireless computer. Make sure your wireless is enabled. Use the wizard you will find in Networking (Control Panel).
I love Network Magic for network management, You may choose to get this program and use it. Google "Network Magic"
I hope you find this post informative.
2helpful
2wire ethernet and wireless lights blinking
They shouldn't become solid. Most lights blink when there is a communication between the devices. It's never a solid connection light.
I was previously using my HP 6735S on wireless but the wireless has now become disabled and I cannot reconnect it. The options on the wireless assistant are greyed out.
HI,
Your laptop must have dedicated switch to turn the wireless on, Once you click that you get Wireless button turned to orange green color symbol. Just try connecting after that
PLEASE RATE THIS SOLUTION IF IT WORKS ELSE LEAVE COMMENTS WE MAY HELP YOU
RNJ VINODKUMAR
1helpful
Secure network becomes unsecure all of a sudden
Sounds like the battery that backs up this router's "firmware" and "programmable" memory settings may be going bad. Then again, it may not have a battery that does this. Perhaps the little reset button on the back is jammed in?
Wireless keyboard and mouse freeze and become completely inoperab
Its probably a compatibility issue with the hardware. The best is to use cabled mouse and keyboard.
How do my window XP laptop become completely wireless? Do I unconnect the blue cord from my computer?
You can only become wireless if you have a wireless card installed/ if you do you don't need to hardwire it
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
