SOURCE: tension
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine.
SOURCE: bobbin tension
This is an issue of your upper thread tension, so take a look at this generic tension solution
If you are in a pickle with your bobbin case, check top tension and bobbin case are free of lint, reset the top tension to 4, and adjust the bobbin tension to suit......some more detail on how to do that, is here
Bargain Box
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
