Frigidaire GLTF2940ES Front Load Washer Logo
Posted on Sep 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code ddo will not start wash - Frigidaire GLTF2940ES Front Load Washer
  • 1 more comment
  • rolandkeioki Nov 01, 2008
    My washing machine reads a ddo code and will not start I found th emagnet but I do not know where it belongs
  • csabbatino May 11, 2010
    OK, I read another problem/solution with a better description about the magnet, but I followed the directions and I neither find a magnet, nor any place that remotely looks like there used to be a magnet there. So I'm going to assume that I have the 'newer model for which they eliminated the magnet'. So if that's the case, how do I fix this on a washer that doesn't have the magnet??
    What do you mean you 'found the magnet'?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
685
Points
I have a Fiegidaire Washer that is saying DDO when I try to start it. I replaced the door lock #131763202 but it still did not start and it still said DDO. Now what should I replace.
Rick
  • Anonymous Jan 25, 2010
    I replaced that already.
Karl Wright
Level 3:
President:
  • Master 1,653 Answers
  • Posted on Oct 03, 2009
Karl Wright
Master
Level 3:
President:
Answers
1653
Questions
Helped
768696
Points
4902
This indicates a problem with the door interlock switch and until resolved the machine will not start.
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
3helpful
The water wont start filling up - it beeps and then has the code "ddo" on the screen.
Thank you !!
2helpful
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
10helpful
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
5helpful
We are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
8helpful
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
4helpful
Error code ddo
the dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
2helpful
2answers
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Our washer has an error code of DDO.
ok if it is the rigt thing for that code there will be a switch on the door have a pen or some thing you can use to trip the switch to thinking the door is closed. and unplug the unit and replug it in.. todays age every thing has to rebooted
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
