Kenmore HE2 Plus Front Load Washer Logo
Posted on Sep 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F06 error code - Kenmore HE2 Plus Front Load Washer
ZJ Limited
Level 3:
  • Kenmore Master 17,989 Answers
  • Posted on Sep 22, 2011
ZJ Limited
Kenmore Master
Level 3:
Answers
17989
Questions
0
Helped
14652161
Points
60866
F6 error indicate a Motor Speed error code. It is likely attributed to either a broken or slipped drive belt, defective Drive Motor, defective Motor Control Unit (MCU), or the interconnecting wiring between the two.
Could be a loose connection in the harnesses, dad Motor, bad motor control board, bad main control board. It's most likely a bad motor control board.
Here is the one parts for your model:
- Electronic control assembly
- Motor Control Unit
- Drive Motor
Also, remember that RepairClinic.com will refund all parts within 30 days that you purchase from them if they don't fix the problem, EVEN electronic parts.
Hope this helps.
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
2answers
1helpful
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
6helpful
2answers
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
3helpful
2answers
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
1helpful
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
