Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
Posted on Sep 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 76 - Brother IntelliFAX 4750 Plain Paper Laser Fax
Anonymous
Level 2:
  • Expert 215 Answers
  • Posted on Sep 21, 2011
Anonymous
Expert
Level 2:
Answers
215
Questions
0
Helped
96332
Points
518
Try this- press the "menu/set" button, then " *2864 " . the *2864 you have to enter within a 2 second window, so you may have to try this more than once. when you hear a long beep, you got it. press "91". you should see "parameter init" on screen. wait for that message to disappear. unplug machine at this point, wait 5 seconds and plug back in. if it comes up with that error again, then you truly have a problem with your fusing unit and will have to have repaired. sometimes though, this error can be caused just by a power outage or fluctuation. if thats the case it should come back up to normal after you successfully do this procedure.
good luck
razors
tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
3helpful
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
Error codes are considered start-point for troubleshooting.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
2helpful
XML Parsing Error at 2:32. Error 76: Mismatched tag
what website? This is a programming error that needs to be sent to the administrator.
Machine error 76 is appearing
Error 76 is a fuser error, you can try going in and out of service mode, press the following key combination all within 2 seconds " features or function , * , 2 , 8 , 6 , 4 , " if done fast enough the all the lights willl be flashing. Them exit out of service by pressing 99. If the error returns after startup the fuser will have to be replaced.
13helpful
2answers
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
5helpful
How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
