SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
SOURCE: Gqrmin 350 GPS Receiver wont turn on
i have a 350 garmin and it when i put in a name of a place it says no matches found??? how can i fix that???/
SOURCE: Garmin nuvi 350 battery replacement
I can't do it for you, but I have done it myself. See the instructions on my webpage at www.dacust.com/nuvi350/index.html. Pictures and everything, along with where I got my battery and the part number, etc. Warning, there are many opportunities to damage your unit doing this. Not for the novice.
-dan
SOURCE: My Garmin 305 has stopped working. It is 1 1/2
If it won't start, try connecting it to your computer and see if you can get a firmware update to turn it on. Otherwise I would send it into garmin since there aren't replaceable parts for consumers.
Benjamin
SOURCE: my garmin won't turn on. I have tried the plug in
it does have an internal battery, but that normally wont prevent it
from turning on unless the battery is defective.
plug it in to the usb cable on your computer for a while (normally it will start right up) then slide to power switch to the on position for about ten seconds.
if that fails, press and hold the lower right corner of the screen and then slide the power switch to the on position while holding the lower right corner of the screen and follow the directions once it starts
i can give you something else to try before you go and spend money on a battery...a battery should be the last thing to do, even though it will more often then not fix the problem thats tempory..
if it turns out you think you need a battery, i will point you to one with instructions on how to change it.
bill
