Posted on Sep 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem when printing i get lines on my photo ,s
Anonymous
Level 3:
Genius:
  • Master 1,550 Answers
  • Posted on Sep 13, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1550
Questions
Helped
457965
Points
4209
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem.
If it is vertical line then it indicate an almost empty or faulty toner cartridge or some spilled toner inside the printer.
if you require further help feel free to ask
mention your model no
how old is your printer ?
Thanks for using Fixya
SAM ANDERSON
Kodak c140 photos shows horizontal lines
I think, it's a CCD Error. That means a complete Line fails.
1helpful
Horizontal lines in photos
Do head cleaning. Print at best photo quality.
When I view my photos they have tiny horizontal white lines on them (and they also print with these lines on as well) ????
hi there 2 reason is here.
1. LCD damaged. In print out photos must be clear.
2. If lens have small tiny screch lines then printed
photos also come with that lines. Thanks.
1helpful
Hp 8500-printing yellow lines across photo prints
I have an HP 8500 printer. When printing photos it prints lines spaced 1" apart accross the entire photo?
Dan
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
1helpful
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
2answers
Lines on a photo when printed
The print quality usually depends on the program you're using to print them on your pc.
Your camera only ever sends photos to your printer, so the best settings are already selected by the camera and it's built-in photo program.
Your printer doesn't 'know' whether your printing a document or a photo, so the settings for each program on your computer are basic (known as default settings), and need to be changed by you to get the best from your printer
Find the settings that let you alter the printers options (in Word, it's FILE \ PRINT \ PROPERTIES), and make sure the printer output is set to maximum quality, and that photo paper is selected as the paper type.
Some options such as 'maximum quality' only appear when you've chosen 'photo paper', and some printers (such as the ip4300) have seperate options for gloss or matte paper, so go through all of them until you see what you need.
Hope that helps :)
Printer lines in photo's
Click Start - All programs - HP - HP Solution center.
In HP solution center Click on the Printing Shortcuts tab. Select Photoprinting with borders or borderless. Click OK.
Then close the HP solution center. Try printing. Print photos always with Best quality.
If the issue persists check the ink level of both cartridges and use Photos Cartridge HP 58 to print photos. We insert the Photo cartridge in place of black cartridge.
Thanks
Blue lines all over the printing
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Top Cannon Office Equipment & Supplies Experts
Dennis
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
