SOURCE: Olympus DM-20 Voice Recorder not turning on
Check the batteries contact especially at the battery cover. It may happened rusty if you leave the battery for a long time when the recorder not in use.
SOURCE: my dm-20 seem to have some recorded in its memory
More than likely you would need to format the device. This will clear all data that has been previously recorded. In your menu there is a format option. Run that and the memory would then be reset.
SOURCE: Olympus DM-20 erase lock is on, how to undo it?
The voice recorder is in read only status - you will need to format the device to remove the lock (read only). Go to menu - to submenu and then run the format option. make sure all files have been downloaded as once device is formatted all files will be permanently deleted
SOURCE: Where can I find the software and drivers of
Software downloads are available at www.olympusamerica.com
