Plantronics PLX500 Headset Logo
Posted on Aug 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect the planronics plx500 to the phone? what is the use of each one of the bottoms?
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 537 Answers
  • Posted on Dec 20, 2011
Anonymous
Expert
Level 2:
Prodigy:
Answers
537
Questions
0
Helped
165276
Points
569
Unfortunately finding life on another planet would be easier than locating an ancient (electronic years) PLX-500 user guide. However, I happen to have one of those ancient writings (no, it wasn't in a cave at the Dead Sea), albeit a bit tattered and yellow, so I'll try and give you a rundown of it's various features.
The top buttons for headset/handset and mute, and listening volume wheel are pretty self-explanatory. Now let's talk about connecting the PLX-500 to your phone and the other amplifier features.
1) Disconnect the telephone handset cord from telephone base and insert the PLX-500 modular plug into the handset jack on the phone. You then insert the coiled handset cord into the back of the PLX-500 base (there's only one place it can go into).
2) Plug the cord from the headset into the jack in the front of the PLX-500.
3) On the back of the PLX-500 base there are two switches (1-2 and 3-4). These are used to configure your PLX-500 to your phone (most electronic single and multi-line phones, such as Panasonic, will use setting 1 and 4). You will have to configure the PLX-500 to your specific phone. Having connected your PLX-500 to your phone, put on your headset, press the headset button on the base, lift the handset of the phone cradle and listen for a dial tone. Adjust the switch settings until you hear the best dial tone.
4) Remember that your PLX-500 uses batteries located under a cover on the bottom of the base (some phones will work without your PLX-500 needing batteries, check configuration before installing batteries). Speaking of the cover, there is a small plastic screwdriver attached to it that you use for adjusting the volume of your microphone. That adjustment is located on the back of the PLX-500 base next to the configuration switches.
Hopefully this gets your PLX-500 up and running.
Good luck from Headsets Direct!
Top Plantronics Radio Communications Experts
Narseman
Frank Fernandez
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
