Washing Machines Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E001 code - Washing Machines
Anonymous
Level 2:
Novelist:
  • Expert 166 Answers
  • Posted on Sep 10, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
166
Questions
0
Helped
44245
Points
348
Peace Friend,
ngafm At your service!
I would love to help you , but I need more info!
You have a e001 code!
What is your make and model # and what type of machine has this code ?
Washer or dryer or?????????????????????
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT.
If not only a trained laundry tech can make the electronic diagnoses.
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Canon ir 5075 error code e001-001
Abnormal rise in temperature and humidity
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
1helpful
Canom imagerunner 2520 error e000001
the e001 is error for the temperature rise detection in fixing unit. There are more sub codes that I need to know for precise troubleshooting. i.e. E001-000 or E001-001 or E001-002
But if there is no fault in components, you can try to reset it in service mode.
Procedure:
additional function, then press 2 and 8 then go in clear by pressing scrolling, then go in engine, then choose ERRCLR and then turn off and on the copier.
If these doesn't helps you need to replace fixing film unit.
1helpful
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
3helpful
Error code E001; machines switches itself off after displaying this code. What does this mean?
Your in luck, Canon really did not change there error codes from way back then..... A E001 means you have a problem with the fusing unit. You may have a blown thermal fuse or one of the heatting lamps or you may have a bad thermister. It may be one or all of them. Did you try to rest the error code?
2helpful
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
3helpful
2answers
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
14helpful
2answers
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
