My tally printer T6218 IS printing half page only
what should i do? please help
<<You can get a full page by printing at 150dpi.>>
Where is this setting found? I'll try changing it.
I have an Epson C120 Ink-Jet Printer that stops printing at
perferated sections. The printer is new and I've cleaned it
and adjusted paper quality settings. Am considering returning it.
Any advise?
On photos, If you have a laser printer with half a meg of RAM and you try and print a full page graphic at 300dpi you only get half a page because the printer runs out of RAM. You can get a full page by printing at 150dpi. could also be that the encoder strip has become fogged with aerosol, and needs gentle cleaning. Good luck
I have a canon iP1500 printer. It's been working fine but all of a sudden it only prints half a page or an incomplete job. I already tried cleaning the heads, checking the page size, etc. I also uninstalled and reinstalled the printer software and this did not work either. Any help will be much appreciated.
I have problem with Lazer beams these are not printing correctly.
after cleaning it prints aboutfour lines and fades to nothing
I try printing and printer prints half of page, spliting it in half.
If I shadow part of a document, it will do the same.
Printer is Lexmark X 3350
bajar software free
Check your transfer roller. Most print defects are commonly caused by defective toner cartridge or dirty tranfer roller. Be sure to snugly feed the paper and the setting is according tothe type of paper you used. Or see if one of your cartridge is empty or low on ink. It does not print altogether once one of the color is insufficient.
