I NEED TO FIND OUT HOW TO PROGRAM CODES INTO THE R.C. I HAVE A RCR4258. PLEASE HELP.
Several other fixya posts address this same remote.
The manual and codes can be found at http://66.77.167.109/rcaaccessories/docs/man/RCR4258_DOC_OM.PDF (found using RCA.COM )
www.rca.com
place model number in search box Search: RCR4258
Click picture of your remote.
Click support and manuals tab located under description
click manual link
Open Adobe Acrobat file.
If you have the manual and are sure you have followed the directions, then your tv or other device may not be compatible.
If you are looking for the code for a specific device, please provide more information.
SOURCE: RCR4258/RCR4358 Universal Remote
No tengo el codigo ,pero puedes buscarlo con el siguiente metodo.Primero enciende tu tv.,despues presiona en el control remoto la tecla code search hasta que el led se quede encendido,presiona la tecla tv. y sueltala a continuacion vas a tener que presionar y soltar la tecla power hasta que el aparato se apague cuando lo haga presionas la tecla enter y el codigo queda almacenado.
Espero que te sirva saludos.
SOURCE: TRYING TO PROGRAM A RCA
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional):
We could not find an exact match, we think this code will work. 10054
Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
I lost my instructions and I need to know how to program the codes into this remote control.
i lost my instruction
