SOURCE: I was trying to clean
I think the main problem with this machine is that the grounds fly all over inside when grinding and combine with the steam and hot water and eventually gum up the moving parts. This causes the latch for the filter basket to lose its grip sometimes and the door pops open during the brewing cycle...I was trying to take apart the slides to clean them out and made the mistake of removing the small screw underneath the left slide. Then the spring popped out and it took about an hour to get it back together, very frustrating. I ended up bending one end of the spring into a slight hook with a needle nose pliers so it would catch better on the "nub" that is connected to the side button. The best way I figured out to clean the slides so far is to blast them out with compressed air periodically for preventative maintenance. I use one of those cans normally used to dust off electronics and insert the straw into the slides.
SOURCE: bosch porsche 9110 drip coffee maker
mine just broke this morning! i just ordered the same part from appliancepartspros.com - the part number is AP2807555. It is currently backordered until 4/25/09 - hopefully I will get that and the other part I ordered. Hope this helps.
SOURCE: water backing up
Hello felicia24,
This is a common problem with this unit.
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times or backing up. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used a eyeglas screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
SOURCE: ESTRO VAPORE
I just took mine apart, and put it back together. Of the three holes for the screws, there are two smaller and one bigger hole. Align the larger hole on the filter and the base, and the tiny plastic bit and the spring go in to the larger, along with the hollow and larger screw.
