Hello Evitan,
From Start Menu >> Run, type regedit and this will open the registry editor. Navigate to the path below :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
If the registry key Storage DevicePolicies key does not exist, you will need to create it.
Download
the batch file called add.bat from below link, and double click after
download the key will be automatically added to registry.
http://www.troublefixers.com/wp-content/uploads/Miscellaneous/add.bat
Double click the key Write Protect
in the right pane and set the value to 0 in the Value Data Box and
press OK button. Exit Registry, restart your computer and then again
re-connect your USB pen drive on your computer. That is it, done.d set
the value to 0 in the Value Data Box and press OK button
