Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Write protected cannot format the usb. - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Aug 18, 2011
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
38659
Points
523
Try to remove partition on to disk management tools and make new partition then reformat the USB drive be careful not to delete the other drive.. or use a software that can manage drives like paragon or acronis partition manager .
Najib Safi
Level 3:
Guru:
  • Master 561 Answers
Najib Safi
Master
Level 3:
Guru:
Answers
561
Questions
0
Helped
66386
Points
1317
Please check there will be write protected button on, just off it and then format
File Repair Services
Level 3:
  • Master 827 Answers
Master
Level 3:
Answers
827
Questions
0
Helped
300551
Points
3317
Hello Jaq,
From Start Menu >> Run, type regedit and this will open the registry editor. Navigate to the path below :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
If the registry key Storage DevicePolicies key does not exist, you will need to create it.
Download the batch file called add.bat from below link, and double click after download the key will be automatically added to registry.
http://www.troublefixers.com/wp-content/uploads/Miscellaneous/add.bat
Double click the key Write Protect in the right pane and set the value to 0 in the Value Data Box and press OK button. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.d set the value to 0 in the Value Data Box and press OK button
2answers
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
7helpful
2answers
How to reformat a write protected usb?
No need to reformat your write protected USB. The hings you should do is to slide to small button you can see in your USB to remove the write protected.
1helpful
2answers
Usb not formating due to write protect
Some usb pen drives,  if thats what you mean? They have a little button on the side of them to protect the contents of the usb pen drive. Check that, tyhen go to "My Computer" look for pen drive, Right click and format.
 Best of luck.....
2answers
My usb drive is write protected i cant format it pls help....
Have you tried doing it from another PC? If the same problem persists, look closely at your drive and check for a tiny switch that has a lock label on it- it maybe switched to the lock position. Most USB drives has this switch for write protection.
1helpful
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
6helpful
1helpful
HOW TO FORMAT A WRITE PROTECT USB DRIVE
I try to answer this even it is late.
If this doesn'thave any movable switch. Actually very small switch on part of it. You got virus in it. Usually it is hidden, and usually name AUTORUN.INF. run scan to your usb drive.
3helpful
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
69helpful
7answers
repair_v2.9.1.1.zip
good program. kdt100-4gb now is ok
Top Kingston Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Narseman
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
