Honeywell QuietCare HCM-630 Humidifier Logo
A
Anonymous Posted on Nov 29, 2005
Not working. When I turn the humidifier on it does not come on.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 16, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3668
Points
Tip worked great on float assembly.
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 277 Answers
  • Posted on Nov 29, 2005
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
277
Questions
20
Helped
170164
Points
437
A console humidifier that fails to humidify a room could have a bad humidistat, fan switch or float switch--problems that take specialized equipment to diagnose. But before you call in a pro, it's worth your time to test the fan motor and float assembly, since repairing them is something you can handle on your own. Testing and fixing the fan Steps: 1. Test the fan motor. While the machine is plugged in and full of water, turn both the humidistat knob and fan-control knob to high. If the fan hums but does not turn, or turns slowly, the motor needs to be replaced. If the fan won't move, you may have a bad switch somewhere. Call a professional. 2. To replace a bad fan motor, unplug the machine and disconnect the fan wires from the switch panel. You may have to pry apart a plug, use needle-nose pliers to pull the connectors off the switch, or unscrew the connectors. 3. Remove the old motor from its housing, using a Phillips screwdriver or a nut driver and socket. 4. Remove the fan blade from the motor. Use adjustable pliers to open the spring clamp at the center of the fan blade, and then slip the clamp off. Use a flathead screwdriver to gently pry off the blade, then set it aside. 5. Take the motor to an appliance store to buy a replacement. 6. Install the fan blade on the new motor, then install the motor and reattach the wires. Testing and fixing the float assembly Steps: 1. Locate the empty tank float assembly. This assembly consists of a switch, a connecting rod (on some units) and some type of float. It's supposed to shut down the machine when the water reservoir is low, but if the float jams in the down position, the dehumidifier won't turn on. 2. Check the float and connecting rod, if there is one. If the parts are bent and touching the cabinet, use gentle hand pressure to straighten them so they move freely. If your dehumidifier has a float switch that is triggered by the filter housing moving up and down, make sure the housing is centered in its tracks and moves freely. Clean any debris and dirt out of the channels, using a scrub brush. 3. Check that the float connecting rod is contacting the float switch. If it isn't, bend the end of the rod so it touches the switch.
A
Anonymous
Some units (BU2200 Bionaire) have a fuse which could be blown.Fan will still work even if fuse is blown but no mist is generated.
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3668
Points
Very helpful. I think I must have thrown one away with this problem and didn't think to check the internet. The float assemby instructions worked perfect and my cow is working well. Thanks
1helpful
2answers
The humidifier was running.Because water lecel was low. I filled it as usual. Now it doesn't run. Why
There could be several reasons why a humidifier stops running after refilling it with water. One of the most common reasons is that the humidifier's float switch is stuck in the "low water" position, which prevents the humidifier from turning on even after refilling it with water . Another reason could be that the humidifier's water level sensor is malfunctioning, which causes the humidifier to stop running even when there is enough water in the tank/
If you have a whole-house humidifier, it could be that the humidistat is set too low, which causes the humidifier to turn off even when there is enough water in the tank 1. Alternatively, if you have a portable humidifier, it could be that the unit's motor has burned out or that its fan has stopped working .
To troubleshoot this issue, you can try cleaning the float switch or replacing the water level sensor if they are damaged. If you have a whole-house humidifier, you can try adjusting the humidistat to a higher setting. If you have a portable humidifier, you can try replacing its motor or fan
Oct 14, 2023 • Humidifiers
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
I think my humidifier does not work. I switch the control button to outside temperature rating and inside the house the humidity level is 11%, which is to low. What should I check? How do you know that...
On the water line running to the Humidifier there should be a On/Off valve. It may be a saddle type valve. In any event, this is how you can tell if the water to the humidifier is turned ON. Look for either plastic or copper tubing running from a water source to the humidifier.
Our humififier ismaking a squeing noise. Why?
The model 550 is a bypass humidifier that does not have any working parts located within it. The squeaking noise that you are hearing is most likely not associated with the humidifier. If turn the dial on your humidstat all the way off, does the squeaking noise continue to occur? When you deactivate the humidifier by turning the dial on the humidstat to the lowest setting or off, and the noise continues to occur that is being produced by another product other than your humidifier.Please respond if issue is not resolved.
2helpful
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Aprilaire humdiifier not working
Does your humidistat have any dip switches or a small jumper wire? if it does try switching positions of the jumper or change dip switch. hope this helps
1helpful
2answers
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
2answers
Honeywell 360a humidifier
yes water should turn off solinoid is bad
2answers
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Paul Carew
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
