Hey there. I'm going to guide you step by step on how to do that.
First of all go to your router configuration by plugging in a cable from any of the available LAN ports into your computer.
Next go to your web browser and type 192.168.1.1 into your address bar.
There will be a prompt for a username and password. Provided you haven't changed system configuration it should be admin and admin
If that didn't work look at the bottom side of your router, it should tell you the default combination.
After that you'll be in the router configuration page. Simply go to the "Wireless" settings.
Under Security, choose Enable and select WPA2(do NOT select WEP).
Put in your wireless security key into the key box and save changes.
After that restart your router and unplug the LAN cable and you should need a password to connect this time. Put in the password from before and if you've done everything right you should be connected to the internet.
Have fun :)
