Dell Inspiron 640m Notebook Logo
Posted on Jun 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I recently changed the motherboard of my dell 640m with a used one. Everything works well but it doesnt charge with the power adapter...When I plug it to the laptop, the small yellow led on the adapter turns off but when I unplug it, it turns back on... Perhaps, it works well with the battery. I tried the power adapter on my other dell laptop and it works perfecly. i would really aprreciate if someone can help me with that matter... Thank you
freespirit_4
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jan 20, 2019
freespirit_4
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
3120
Points
31
You need to see which power supply wattage and voltage works with the replacement motherboard. Obviously it is not the same motherboard, so you may want to figure out the specs on the replacement board, and then replace with a power supply that works with this motherboard. Hope this helps.
Larry Ng
Level 3:
Top Expert:
  • Dell Master 23,260 Answers
  • Posted on Dec 29, 2018
Larry Ng
Dell Master
Level 3:
Top Expert:
Answers
23260
Questions
0
Helped
5161207
Points
90796
So does it run no the power pack alone
the big useless old and shorted out battery left out.
only this matters, and is TEST ONE on all laptops made.
for sure, why not do that first sign of trouble.
http://pcdied.com/dead-PC.html
dell has 5 power packs, and all 5 will not work on both PC so moving the pack proves very little.
what matters is WATTSs.
what wattage is it .?
if you put new 65watt on new pc it works
then move it to old power hog PC it fails.
due to WRONG PACK (ac adaptor)
sadly dell.com page on this old laptop they lost the spec page. dang.
id try the 130w pack first. and do so with that old relic huge battery removed
  • Anonymous Jan 20, 2019
    THE BOTTOM OF SOME DELLS
    THE STICKER LABEL THERE SHOWS
    65w, on the label.
    one I just looked at shows.
    if this GPU screen, use 65w
    if this GPU screen is advanced GPU use 100w.?
    just turn over the laptop\
    and read the sticker,
    the power pack you have can be bad wrong
    wrong and way to week wattage rated.
    reading pack only gets 2 packs wrong,dig?
    some PCs have 3 pack choices for 3 major options in your PC you have not disclosed.
    1 milltionth bad battery today world wide
    who'd have thunk it?
Minister Ruland
Level 2:
Sergeant:
  • Dell Expert 445 Answers
  • Posted on Nov 04, 2018
Minister Ruland
Dell Expert
Level 2:
Sergeant:
Answers
445
Questions
0
Helped
130816
Points
810
Look on he power adapter and some of the old dells has to have a 65 amp and you might have the 90 amp check to see which one you have. the 90 amp is for the docking station
  • 4 more comments
  • Anonymous Nov 06, 2018
    Fshamsudin's post is almost 2 years old now.
    I bet he didn't star at it for that long dead?>
    The battery is bad,12 years old.
    65watts, is not amps.
    Volts x amps = watts (va)
    ok? ohms laws.
    i will read your manual to you page 161 at dell.com
    it shows
    Dell Inspiron 640m Notebook ,65watt pack
    https://www.dell.com/support/home/us/en/...
    no need to guess, or wonder
    but your battery is TOAST as is all this old.
    the correct answer is the battery is no good;. repeated here 10,000 times endless
    battery main can fail in 1 year.
    a fact your battery maker tells you clear as day if abused
    running on battery full time is abuse.
    fact.
  • Anonymous Dec 25, 2018
    another battery bites the dust, (rim shot ,beat)
    did it last 12 years?
  • Anonymous Dec 26, 2018
    65watts not amps. ok?
    SO IF THE OLD PACK WAS WRONG SIZE
    YOU THEN COPY WRONG/. WOW,.
  • Anonymous Dec 29, 2018
    yes all laptops made run power packs from
    as low as 35watts, (new) to older as hight as 150 watts, mine is 240w. and needs that because the
    the processor on mine (fast i7) sucks 50 watts an the GPU near the same due the ultra fast GPU option in mine/
    each PC has sub model number (laptops)
    that tells a technician what options are in this PC. and the power pack size is based on that set of facts and that alone.! (called a power budget)
    what is needs is covered in his matching manual on his unstated PC. (but i cant find it)
    or the bottom sticker of laptob bottom case
    shows watts clear as day,LOOK here first.
    only dell can answers watts min.
    if not bottom of pc sticker.
    here is there page , under power errors
    read this quote. only the full service tag on all PCs made tells a real tech what is needed
    and the OP did not post those key facts
    so ask Dell this. we are not dell;.
    if you bought the PC with wrong pack on it reading the label now is DAFFY duck bad.
    "Dell laptop PCs may use either a 65W (Watt), 90W, 130W, 180W or 240W AC adapter. For optimal performance, use the AC adapter that came with the Dell laptop PC. AC adapter's wattage information is printed on the label which is located at the bottom of the AC adapter."
    off hand a 90w should do it. about 5 Amps
    if guessing guess large, 130w would be plenty.
    i see dell lost the spec page on this PC
    i see the largest pack ever sold for this PC is 130w. (lost in the sands of time)
    you can ask on dell.com rel forum
    be super wise to do ,known the documents are lost in the support page
    btw, fixya has zero documents here.
    zero, we can use rabbit in hat trick here.
  • Anonymous Jan 07, 2019
    THIS PC HAS MANY MOTHERBOARD OPTIONS
    EVEN 10 CHOICES PER COUNTRY
    WE CANT GUESS WHAT SUB MODEL YOU HAVE.OK?
    AND MATTERS
    the fasted one sucks the most watts (power)
    this old. ok, the GPU and CPU has wide choices new,and varies greatly,
    called power needs
    and higher is ways better.
    and the pack runs cooler and lasts LONGER too.
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on Sep 14, 2008
SOURCE: My Dell Laptop is not turning on
Try removing the battery, then plugging it in and power ON the laptop without that. Maybe the battery or the battery terminal is shorted out.
Anonymous
  • Posted on Mar 03, 2009
SOURCE: Inspiron 1501 will not power from know good AC adapter.
Hey, i have a solution to this - it involves a cold solder joint on C34 (i believe, i repaired mine a while ago) - but i took pics and stuff. If you need help, feel free to drop me a line at crossan007@gmail.com, or AIM: crossan007
Anonymous
  • 14 Answers
  • Posted on Apr 01, 2009
SOURCE: Dell laptop (E1705). Battery won't charge.
BUY Dell Inspiron E1705 Laptop Battery, you can go
http://www.notebook-battery.us/notebook-battery/dell-inspiron-e1705.htm
Anonymous
  • 130 Answers
  • Posted on Jun 21, 2009
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Anonymous
  • 103 Answers
  • Posted on Aug 12, 2009
SOURCE: where can i get a schematic for a dell inspiron
ARrrghhh finding clear and detailed schematics on parts today can be a real pain in the south-forty -- luckily, i know a site where you can find what you are looking for quickly.
http://www.user-guides.co.uk/cddownload/Dell/DellInspiron/Dell-Inspiron-E1505-Service-Manual-Remove-Upgrade-841.html
just follow this link and you will find a resource for COMPLETE and DETAILED schematics and more.
Hope i was able to FIX YA!!! Please reply with your feedback if this helped or if you need more anwers.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
