Miele 36 in. KM342 Gas Cooktop Logo
Posted on Aug 06, 2011
All the knobs have cracked stems. I need replacement parts.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
267
Points
My knobs did the same _ if you want to avoid expensive replacements (mine were going to be $125) get some small good quality zap straps and tighten 2-3 around the stem. For added strength you could add some apoxy but i found it was not necessary. Good Luck!
2answers
How to lift open a whirlpool gas oven cooktop, have a knob that is loose from inside?
Here is a disassembly video. A loose knob problem can be tackled by pulling off the knob, encircling the cracked plastic with a zip tie (after putting Loctite glue in the cracks), pulling the zip tight. Don't lose the sleeve when you pull off the knob. But if this is not working for your setup, here is the disassembly, not your model but maybe useful: https://www.google.com/search?q=whirlpool+gas+top+disassembly
Simpson EZISET cooktop control knob does not turn
Take some electronics contact cleaner, CRC is best, and spray the knob. It has grease inside that is preventing the spring from popping it up so it turns. You'll need to get a new knob eventually and please don't install it yourself unless you are well versed in working with gas.
May 08, 2015 • Cooktops
Whirlpool How To
so sorry for the way late reply!
if the knob does not fit you'll need a new one...
i found them here....
https://www.repairclinic.com/Shop-For-Parts/c31-x72636333303234/Rcc3024-Knob-Dial-Button-Parts
not sure which is yours as the model # should have a few more # or letters. Take a look at them and see if one matches.
best to you.
Good advise on removing the knob. My problem is that the Valve stem has excessive play in it. How do I replace valve stem.
Hi, the valve stem on a gas stove is on a manifold assembly under the top. If I am correct in remembering, the burner valve unscrews to replace them. If so, take it with you along with all of the numbers,M#, S #, and so on. Best of Luck,
Shastalaker7
1helpful
How to remove the knobs and replace gas valve on DCS 36" gas cook top - looks like wobbley stem.
The knobs should just pull straight off. Don't tilt or bend them around, just pull them straight. off.
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
1helpful
Old kenmore gas cooktop with griddle
If the knobs will not push down and turn, this indicates the gas valve stem has become contaminated with cooking debris. The only solution to this, would be to replace the gas valves. With the cooktop more than 10ys old, parts may be difficult to find. If you can find parts, they will probably be prohibitively expensive.
Top Miele Cooktops Experts
gerbee gomez
Paul Carew
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
