Friedrich QuietMaster KM24L30 Wall/Window Air Conditioner Logo
Posted on Aug 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to get the drain on my friedrich quietmaster model km24l30 unplugged. what is the best way to go about this?
Anonymous
Level 3:
  • Friedrich Master 43,501 Answers
  • Posted on Aug 06, 2011
Anonymous
Friedrich Master
Level 3:
Answers
43501
Questions
0
Helped
11051790
Points
101587
If you have a slide out chassis then slide the unit out and the drain will be in the back corner of the pan...you can then easily see it and get it open...
If it does not slide out then look in the back corners for a hole and use a wire to get the hole open...DO NOT run a drill up in there, you will drill a hole in the coil!!! I have fix a few of those..:-)
heatman101
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Show drain hole on bottom of Friedrich window unit
it gets rid of condensate by a slinger ring on fan motor throws it up on condensor and evaporates it.
Where is the drain hole on my frederich quietmaster wall air conditioner?
Hello, if there is no drain hole under the unit then it uses the fan blade to sling water on the condenser to evaporate the condensate. Some window units are made this way instaed of using a drain hole.
1helpful
Unit cools then sound like hissing noise then stops cooling sound like relief
Hi, this hissing you hear is the head pressure getting very high in the system due to the out door coil is very dirty. It shuts the compressor down until it cools off again, then repeats its self again. Take a water hose and wash down the outdoor coil being careful not to flatten the aluminum fins. This will solve your problem! Good luck,
Shastalaker7
A/C, Contractor
The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Water Leaking into room
if you can see a drain blow backwards through it.It may also just be angled the wrong direction(the whole unit).If you cant see an external drain,unplug the unit and take the cover off .you should then be able to clear it.
Resetting Quietmaster
UNPLUG IT FOR 30 SECONDS AND PLUG IT BACK IN
Top Friedrich Heating & Cooling Experts
jdthefixer
john h
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
