20 Most Recent Escali C3315 Counting Scale 33Lb/15Kg 1g/0.1oz Resolution Questions & Answers
My acurite model 01046/02081 outside temperature reads alot warmer then it is it's placed less then 300 feet from weather station outside but the prediction and temperature reading is way off
Businesses today depend on reliable technology, making it essential to choose the right IT partner. Ashcode IT is recognised as a trusted IT support company in Dubai, offering services such as network security, structured cabling, CCTV installation, WiFi setup, and managed IT support. With a strong focus on performance, security, and long-term reliability, Ashcode IT helps businesses maintain smooth operations and secure IT infrastructure. Their professional approach and timely support make them a preferred choice for companies across the UAE. ?? https://ashcodeit.com/ ?? +971 4 393 4773 ?? sales@ashcodeit.com
3/29/2026 7:04:12 AM • Measuring Tools... • Answered on Mar 29, 2026
Want to purchase a 34788NI-H Rob Cooltech machine. This year GM made us buy the same piece of equipment but for the 134yf Freon. That machine is extremely slow, is the 34788 that slow also?
Why Your 1234yf Machine Feels Slow R-1234yf machines are intentionally slower because:
  1. ?? Refrigerant is mildly flammable (A2L classification)
  2. Extra internal purging cycles are required
  3. More leak checks
  4. Vapor recovery safety delays
  5. Tank temperature stabilization cycles
That's normal. All 1234yf machines run slower than 134a machines. ? Is the 34788NI-H Slow? No - the 34788NI-H (R-134a) is generally:
  • ? Faster recovery
  • ? Faster recharge
  • ? No extended safety purge cycles
  • ? Proven compressor design
  • ? Widely used in dealerships
Typical performance (approximate):
  • Recovery rate: Around 0.5 lb/min vapor (faster on liquid)
  • Full service time: 20-35 minutes depending on vehicle
Compared to 1234yf machines, it feels significantly quicker. ?? Real-World Comparison Feature R-134a (34788NI-H) R-1234yf Machine Recovery speed Faster Slower Purge cycles Minimal Multiple Recharge time Quick Longer Safety delays No Yes Overall service time Shorter Longer
3/3/2026 10:35:51 AM • Measuring Tools... • Answered on Mar 03, 2026
Which outdoor unit temp sensor shwo me
Outdoor Ambient Temperature Sensor (Most Common One People Ask For) ? This is the outdoor unit temp sensor Location:
  • Inside the outdoor unit
  • Clipped onto or near the condenser coil (air inlet side)
  • Small probe with 2 thin wires
  • Connected to the main PCB
  • Often labeled: OAT / TA / Ambient
This sensor measures outside air temperature. ?? 2?? Discharge Pipe Temperature Sensor Location:
  • Clamped onto the compressor discharge copper pipe
  • Insulated with black foam
Measures compressor outlet temperature. ?? 3?? Condenser Coil Temperature Sensor Location:
  • Attached directly to the condenser coil tubing
  • Usually clipped into the fins
Monitors coil temperature for defrost and protection. ?? If You Are Asking: ?? "Which outdoor unit temp sensor?" The answer is: Outdoor Ambient Temperature Sensor (OAT) That is the one that reads outside air temperature. ?? How To Identify It Quickly Open outdoor panel (power OFF first):
  • Look for thin 2-wire sensor
  • Not attached to copper pipe
  • Clipped to metal frame near air intake
  • Goes directly to PCB labeled "Ambient" or "TA"
3/3/2026 10:32:17 AM • Measuring Tools... • Answered on Mar 03, 2026
Blue star vrf outdoor temp sensor show me now
Where to Find the Outdoor Temperature Sensor On a Blue Star VRF outdoor unit, the sensor is usually:
?? Location
  • Inside the outdoor condenser unit
  • Mounted near the air inlet coil
  • Clipped onto or positioned close to the condenser coil fins
  • Connected by a small 2-wire harness to the main PCB board
It is not external like a weather station sensor - it is inside the unit casing. ?? How to Access It (Technician Method) ?? Only do this if power is OFF.
  1. Turn OFF power at the breaker.
  2. Remove the outdoor unit front or side panel.
  3. Locate the main control PCB.
  4. Follow the thin thermistor wires labeled:
    • "Ambient Temp"
    • "Outdoor Temp"
    • Sometimes marked "TA" or "OAT"
The sensor looks like:
  • A small metal or black plastic probe
  • Attached to thin wires
  • Usually clipped to the coil frame
?? How to Check If It's Faulty Common signs:
  • Wrong outdoor temperature displayed
  • System overcooling or undercooling
  • Error codes related to ambient sensor
  • Compressor not ramping properly
You can test it with a multimeter (ohms):
  • Most Blue Star VRF sensors are NTC thermistors (usually 10k? at 25°C).
  • Resistance decreases as temperature increases.
If readings are open circuit or very high/low compared to temperature, it may be faulty.
3/3/2026 10:31:16 AM • Measuring Tools... • Answered on Mar 03, 2026
I need instructions on how to set up model T85647 of. My wireless forecast Station..
etup Guide - T85647 Wireless Forecast Station ?? Step 1: Install Batteries (Important Order)
  1. Insert 2 AA batteries into the outdoor sensor first.
  2. Wait about 1-2 minutes.
  3. Insert 3 AA batteries into the main display unit.
?? Always power the sensor first so it syncs correctly. ?? Step 2: Let It Sync
  • Place the sensor within 1-3 meters of the display for initial setup.
  • Within a few minutes, outdoor temperature/humidity should appear.
  • If it doesn't:
    • Remove batteries from both units.
    • Wait 5 minutes.
    • Repeat setup in correct order.
? Step 3: Set Time & Date
  1. Press and hold the SET button on the back until the display flashes.
  2. Use + / - buttons to adjust:
    • Time zone
    • 12/24 hour format
    • Hour
    • Minutes
    • Year
    • Month
    • Date
  3. Press SET to confirm each setting.
If your model has atomic time, it may auto-update after a few hours. ?? Step 4: Place Outdoor Sensor
  • Mount under a roof overhang.
  • Avoid direct sun or rain.
  • Keep away from metal surfaces.
  • Ideal height: 1.5-2 meters above ground.
Wireless range: up to 90m in open air (less through walls).
3/3/2026 10:30:07 AM • Measuring Tools... • Answered on Mar 03, 2026
3answers
I have a volt,amp and watt meter.there was no
Sure, what and how would you like me to help you with?
The Volt meter probably has two different voltages to work with. One, is AC voltage. The AC (alternating current) sign looks like a slight horizontal S-shaped symbol. Your basically going to use this a majority of the time.  DC (Direct Current) voltage is used for battery related sources. But don't get to confused with this. Just keep it on AC for all house power voltage checks (eg. 110v or 220v) applications. Two, Amp meter? This is used to measure the amperage being used or drawn on that particular circuit, or motor. This is very helpful in determining if there's an overload problem. You'll use this in your electrical panel to check how many amps are being drawn on each particular circuit. It's very helpful in troubleshooting motors also, but you use it more for the latter application when it comes to working around your home. And Watts? Wattage measures power output. If you multiply Voltage times Amperage...you get Wattage (Ohm's Law). For residential use, most wattages are on your hair dryers, plug-in appliances, etc. Now that you know how to find wattage through multiplying voltage and amperage - you can tell if you're overloading a circuit, or in some cases - realize you're under not overloading the circuit, and then you'll want to check out your circuit breaker. Because this is a good barometer to finding a circuit breaker in the beginning phase of going bad. And last, but not least, you can get the make and model of your meter - and Google the manufacturer, and try to get the instructions on-line. Or, you can contact them and request them to send you one if you prefer a hard copy. Sometimes, they'll e-mail it to you - or they'll have you download it from their website. I hope this gives some direction. Feel free to contact me again if you have any further questions. Good Luck to you, and I hope this works for you. - Jim
12/4/2025 7:03:37 AM • Measuring Tools... • Answered on Dec 04, 2025
XC0366 wireless weather station: changed batteries but Still no signal from remote sensor
Troubleshooting Steps 1. Correct Battery Installation Order - Always insert batteries into the outdoor sensor first, then the indoor display. - This allows the display to scan and sync properly. 2. Check Sensor Batteries - Use fresh alkaline batteries (not rechargeable). - Avoid mixing old and new batteries. - Double-check polarity (+/-) in the sensor. 3. Re-Sync the Units - Remove batteries from both units. - Wait 2-3 minutes. - Insert batteries into the sensor first, then the display unit. - Wait up to 3 minutes for signal detection. 4. Check Distance and Obstructions - Place the sensor within 1-3 meters (3-10 ft) of the display during syncing. - Walls, metal, and electronics can block signals-avoid interference. 5. Channel or Frequency Setting (if available) - Some models have an A/B/C channel switch-ensure both sensor and display are on the same channel. 6. Factory Reset (if available) - Look for a reset button or pinhole on the display. Press/hold to reset the system
10/24/2025 3:39:57 PM • Measuring Tools... • Answered on Oct 24, 2025
How to program digital indoor/outdoor wireless thermometer
?? Basic Setup Instructions 1. Insert Batteries (Important: Do in Correct Order) - First insert batteries into the outdoor sensor. - Then insert batteries into the indoor display unit. - This ensures proper syncing between devices. 2. Auto Syncing - Wait a few minutes. Most units will automatically detect the sensor signal. - A wireless icon or temperature reading should appear for the outdoor sensor. 3. Set Time & Date (if supported) - Press and hold the "SET" button on the display unit. - Use ? / ? buttons to adjust hour, minutes, year, month, and day. - Press "SET" again to move through settings. 4. Select °C / °F - Most models have a button on the back or in the settings to toggle between Celsius and Fahrenheit. 5. Channel Selection (if multiple sensors supported) - Outdoor sensors often have an A/B/C switch. - Set both sensor and indoor unit to the same channel. 6. Mount Sensor Properly - Place the outdoor sensor in a shaded, dry location, avoiding direct sun/rain. - Range is typically 100-300 ft (30-90 m) depending on obstacles.
10/24/2025 3:38:14 PM • Measuring Tools... • Answered on Oct 24, 2025
Craig Wireless Weather Station Model CS1203
Here's a quick setup guide for Craig Wireless Weather Station Model CS1203: 1. Insert Batteries - Insert fresh batteries into the outdoor sensor and the indoor display unit. Make sure they are inserted correctly. 2. Place Outdoor Sensor - Mount the outdoor sensor in a shaded, well-ventilated area outside. Avoid direct sunlight or heavy rain exposure. 3. Sync Sensor and Display - The indoor display should automatically detect the outdoor sensor signal within a few minutes. If not, press the "Search" or "Sync" button on the display (refer to your manual if available). 4. Set Time and Date - Use the buttons on the display unit to set current time, date, and other settings as needed. 5. Check Readings - After syncing, the display will show indoor temperature, outdoor temperature, humidity, and other weather info.
10/24/2025 3:34:21 PM • Measuring Tools... • Answered on Oct 24, 2025
I have an Acurite 1099RX. All works fine except I cannot figure our how to set time and date. Help please.
The AcuRite 1099RX is a multi-function weather station with a wireless outdoor sensor and indoor display, but it does not auto-set the time/date, so you'll need to set them manually. Here's how to set the time and date: --- ?? Steps to Set Time and Date on AcuRite 1099RX 1. Press and Hold the "SET" Button - On the back or front panel (depending on your model), locate the "SET" button. - Press and hold it until the hour starts flashing. 2. Set the Hour - Use the ? (up) or ? (down) buttons to adjust the hour. - Make sure AM/PM is set correctly if your unit uses 12-hour format. - Press SET again to confirm and move to minutes. 3. Set the Minutes - Use ? / ? to adjust. - Press SET again. 4. Set the Year - Use ? / ? to adjust. - Press SET again. 5. Set the Month - Use ? / ? to adjust. - Press SET again. 6. Set the Date (Day) - Use ? / ? to adjust. - Press SET again to finish. 7. Optional: 12/24 Hour Format or DST Settings - Some versions allow toggling between 12/24-hour format or Daylight Saving Time settings during this process.
10/24/2025 3:17:47 PM • Measuring Tools... • Answered on Oct 24, 2025
Set up instructions for AN7 V31 U for indoor outdoor temperature monitor
?? General Setup Instructions for AN7 V31 U Indoor/Outdoor Temperature Monitor 1. Install Batteries / Power - Indoor (display) unit: Insert the required batteries (often AAA or AA) or plug in via USB if supported. - Outdoor sensor unit: Open its battery compartment and insert fresh batteries (AA or as specified) making sure polarity (+/-) is correct. 2. Initial Pairing - Place the outdoor sensor near (within a few feet of) the indoor display unit right after battery installation. - The display should recognize and show the outdoor reading within a few minutes. - If there is a "CHANNEL" or "CH" setting (e.g., CH1, CH2, CH3) in the outdoor sensor or indoor display, make sure both are set to the same channel so they communicate correctly. 3. Sensor Placement - Outdoor sensor: Mount outdoors in a shaded, ventilated area, away from direct sunlight and heat sources. Typically 4?6 ft above ground is good. Indoor unit: Place away from direct heat vents, sunlight or electronics that might interfere with accurate indoor readings. 4. Switch Units (°C / °F) - On the indoor display, locate the button or setting to switch between Celsius (°C) and Fahrenheit (°F) for temperature display. (Often labelled "°C/°F".) - Choose the unit you prefer. 5. Check Signal & Accuracy - Make sure the outdoor temperature/humidity reading appears on the indoor unit. If you see dashes "? ?" or no reading, check sensor distance, battery strength and channel alignment. - Ensure the distance between the indoor and outdoor unit is within the specified wireless range (commonly up to ~100 m / ~330 ft in open space) and without too many obstacles (metal walls, electronics, thick concrete). 6. Optional: Max/Min Records & Alerts - Some models let you view daily MAX/MIN temperatures (high/low) for indoor and outdoor. - If your device supports alerts for high/low temperatures or humidity, set your thresholds according to user manual. --- ? Troubleshooting Tips - If the outdoor sensor reading is missing or flashing, try: - Replacing outdoor sensor batteries with new high?quality alkaline ones. - Ensuring the channel/sensor setting matches the display unit. Relocating the sensor or display unit to reduce interference (move away from large metal objects, thick walls or electronics). - If readings are inaccurate, ensure the sensor is: - Not in direct sun or near a heat source. - Properly mounted in a ventilated space. - If the display or sensor shows low battery icon, replace batteries promptly.
10/24/2025 3:15:27 PM • Measuring Tools... • Answered on Oct 24, 2025
Set up instructions for AN7 V31 U indoor out door temperature thermometer
However, based on typical wireless indoor/outdoor thermometer setup guides, here are general instructions that should apply - you can adjust slightly based on your exact model. --- ?? Setup Instructions 1. Install Batteries - Open the battery compartment of the indoor display unit, insert the correct batteries (often 3 × AAA or as specified), observing the correct polarity. - Open the battery compartment of the outdoor sensor unit, insert the correct batteries (often 2 × AA), observing polarity. 2. Initial Sensor Pairing - Place the outdoor sensor unit near the indoor display unit (within a few feet) so they can pair. - The indoor unit will search for the outdoor sensor automatically - wait ~1-5 minutes. - If it doesn't pair: check if there's a channel switch (CH 1, CH 2, etc.) inside the outdoor sensor, and set the outdoor sensor and indoor display to the same channel. 3. Place Outdoor Sensor Correctly - Mount the outdoor sensor in a shaded, well?ventilated location (not in direct sunlight or very near heat sources). - Place it high enough (typically 4-6 feet above ground) and ensure it's within the wireless range of the indoor unit (check product for range, e.g., up to 100 m or ~300 ft). - Avoid placing it in direct rain or intense sunlight, unless the sensor is fully weather?sealed. 4. Place Indoor Display - Put the indoor unit in a location away from direct heat sources (radiators, air conditioning vents, direct sunlight) to ensure accurate indoor readings. - Optionally mount on a wall or keep on a tabletop, depending on its stand/hang features. 5. Switch Temperature Units (°C / °F) - On the indoor unit, locate the button or setting to toggle between Celsius and Fahrenheit (often labeled "°C/°F" or "C/F"). - Press this to choose your preferred unit. 6. View Max/Min Records (if supported) - Some models keep track of the highest & lowest indoor/outdoor temperatures (and perhaps humidity) each day. - Use the "MEM", "MAX/MIN" or similar button to view those records. 7. Check Signal and Reading Accuracy - Make sure the outdoor sensor is showing a reading on the indoor display (not "-" or blank). - If the signal is weak (fewer bars or missing data), try moving the sensor closer, changing its location, or removing obstacles (walls, metal objects) between sensor and display. --- ? Troubleshooting Tips - If outdoor temperature/humidity not showing: - Replace outdoor sensor batteries with fresh good?quality alkalines. - Make sure sensor is in correct channel and matched with display. - Ensure sensor is within wireless range and not blocked by large structures. - If the readings seem wildly inaccurate: - Ensure sensor is out of direct sunlight or heat source. - Ensure indoor unit is not near heat/cold vents. - If the display is blank or dim: - Check indoor unit power source or batteries. - Some models require AC adapter or fresh batteries for full backlight.
10/24/2025 3:12:27 PM • Measuring Tools... • Answered on Oct 24, 2025
AN ACURITE PROFESSIONAL WEATHER STATION MODEL 01536CAUDI/8900123
The AcuRite Professional Weather Station model 01536CAUDI (or 01536) is a 5-in-1 station that typically includes: - Indoor color display - Outdoor 5-in-1 sensor (temp, humidity, wind speed/direction, rainfall) If you're experiencing an issue or need a replacement sensor, here's what you should know: --- ?? Sensor Compatibility: The 01536CAUDI usually uses the AcuRite 5-in-1 sensor, commonly identified as: - Sensor Model: 06004, 06014, or 06045 (check back of sensor or inside battery compartment) These sensors are interchangeable for most 5-in-1 display units, including your model. --- ?? Common Needs: 1. Replacement Sensor Look for: - AcuRite 5-in-1 Sensor Replacement Kit (e.g., model 06014RM) - Compatible with your 01536 display 2. Battery Tip - Use high-quality AA alkaline batteries (no rechargeable or lithium) - Change every 6-12 months 3. Signal Issues? - Keep the sensor within 330 ft (100 m) of the display - Match the A-B-C channel on both units 4. Mounting Reminder - Mount 5-6 feet above the ground, in an open space away from buildings for best accuracy --- Let me know if you need: - A link to a compatible replacement - Troubleshooting help - Setup instructions
10/24/2025 3:06:55 PM • Measuring Tools... • Answered on Oct 24, 2025
I need to find an outdoor sensor for my ACURITE weather station MODEL #02483.I have looked on your site as well as Amazon and have found some outdoor sensors but none that are for this Model#
--- ?? What we know - The 02483 is listed in AcuRite's Basic Weather Stations section. [1] - AcuRite's compatibility list doesn't explicitly show "02483" as a model for easily swapped sensors. [2] - Their support documentation suggests that for some models, only whole units (display + outdoor sensor) are replaceable. [3] --- ? Steps to find a compatible sensor 1. Contact AcuRite Support: Use their "Missing Parts / Replacement" section to ask about the exact replacement for model 02483. [4] - Provide your station model number (02483) - Provide the current sensor part number (inside battery compartment of the outdoor unit) 2. Check the sensor's internal ID: Open your outdoor sensor's battery compartment and look for a circuit board ID or part number-this is often required to find a direct replacement. 3. Search generic compatible sensors: If a "02483?specific" sensor isn't listed, sometimes a universal AcuRite outdoor temperature/humidity sensor (radio 433 MHz) will work-just ensure the letter?switch (A/B/C) matches your base unit. For example, AcuRite part 06002M works with many models. [5] 4. Confirm range and radio frequency: - Ensure sensor uses the same RF band (433 MHz) - Ensure signal range from outdoor sensor to base/display is sufficient - Make sure the mounting and weather?proofing match your setup 5. Consider replacing the full station if needed: If the outdoor sensor is proprietary and not sold separately for model 02483, replacing the entire station might be the simplest option. --- ?? Practical Checklist Before Buying - [ ] Model number of your display unit and outdoor sensor - [ ] Sensor part number inside outdoor unit - [ ] Radio frequency and A/B/C switch setting - [ ] Signal strength (ensure outdoor sensor is within recommended range) - [ ] Weather?proof mounting compatibility
10/24/2025 2:43:37 PM • Measuring Tools... • Answered on Oct 24, 2025
All of thes answers refer to watches.My product is a weather station Auriol Z29962D The time is always 1 hour ahead.If I set the time manually,it will eventually go to 1 hour ahead of BS time or 2 hou
Do you have a setting for the power line frequency? Some devices get their timebase from the power line frequency and if your powerline is 60 Hz, but you have it set on 50 Hz, then it will speed it up because of the 10 extra cycles per second.
10/19/2025 5:28:42 AM • Measuring Tools... • Answered on Oct 19, 2025
Outside temp read 80.Smart phone weather said 70.Replaced batteries and did all the troubleshooting. Model 0041/00609SBDIA/00611A3. Less than 1 year old. Inside temp works, dashes on outside reading.
Place your remote temperature sensor and the inside unit together for about an hour to see if they both read the same or if there is a large difference in the temperatures.Dashes on the outside temperature reading may indicate that the inside unit is not receiving a signal from the remote. Change the batteries on the remote or change the location of the inside and/or outside units so that they can receive a strong signal between each other.Your smartphone temperature may be coming from a location that is not near your home. They are often from a weather service. Where is your local temperature sensor located? Is it in the sun? Is it on the south side of the house, or another location where the sun or an air conditioner or other heat source may affect the accuracy of the reading? Try to locate your outside sensor in a shaded location with plenty of ventilation, and away from heat sources.
10/19/2025 5:26:51 AM • Measuring Tools... • Answered on Oct 19, 2025
Weather Station - Model 31215. Why does my wireless thermometer 31215B keep beeping after I have changed the batteries? I don't see a reset button. I have a set/zone button.
Question edited for clarity.Question moved from Misc category.The base station always takes more power and is more battery hungry than the remote thermometer. Your beeping is telling you it can't contact the base because of the base receiver.https://www.google.com/search?q=wireless+thermometer+31215B+beepsMore here.https://vftp.net/n0zyc/gadgets/weather/Equity%20Weather%20Station%20Thermomiter%2031215.pdf..
6/6/2025 12:40:42 AM • Measuring Tools... • Answered on Jun 06, 2025
How to open battery compartment
https://www.manua.ls/taylor/7506/manual?p=2 This site will give you the instructions.
4/11/2025 5:23:54 AM • Measuring Tools... • Answered on Apr 11, 2025
Escali C3315 Counting Scale 33Lb/15Kg 1g/0.1oz Resolution Logo
2 questions posted
Top Escali Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Escali Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Escali Measuring Tools & Sensors
Most Popular Question
temperature incorrect
  • Measuring Tools & Sensors
