Questions & Answers for: f 53 2 error - Page 7
Question about PT-53TW53 53" Rear Projection HDTV-Ready Television
no power when turned on the red light flashs 3 times is this the stk-392-110...? yes the 3 blink error means the convergence circuits have failed they are STK392-110 ICs
Question about 53UWX10B 53" Rear Projection Television
magic focus 4 error What does the magic focus 4 error mean? on a Hitachi rear projection tv Error 4 is listed as an overflow in the convergence section. To fix: 1. Check the placement of the sensor 2.
Question about KP-53XBR200 53" Rear Projection Television
7 blink error code 7 blinks means high voltage shutdown check power supply good luck shaun
Cannon Fax machine JX-200 will not recieve incoming faxes, has message !!check!! 5100 Look on page 53 in this user guide. http://gdlp01.c-wss.com/gds/0900007827/FAX-JX200_JX201_Users_Guide_EN_US.pdf ...
Question about PT-53WX42 53" Rear Projection Television
not turning on power button is blinking How many times is it blinking as thats a error code?
tv not coming on and red led blinking on front panel when I try to power on the blinking led is a error code. Let me know the number of blinks and I will assist you.
Question about PT-53WX53 53" Rear Projection HDTV-Ready Television
turns off immediately then light blinks The blinking power light is a error code. How many times does it blink?
wont work my tv just turned off. the red light next to the power button in the front just blinks 3 times. how can i fix it for cheap. is it a fuse? 3 blinks is convergence error.
Question about Galaxy of Games: Yellow Edition for Windows
...error 53 file not found addon2vb.dll how do i get rid of this. I have a new computer with windows 7 and when i installed this it will not let me play it. Thanks hi, You can go to this site .. ...
error 53.10.03 53.xy.zz CHECK RAM/ROM MEMORY Description There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of
Top Televison & Video Experts
Larry
Are you a Televison & Video Expert? Answer questions, earn points and help others
