53swx10b bowed picture After installing the Sanyo ic repair kit I have a great picture that is bowed at the top and bottom. Also, the magic focus no longer works. Any suggestions as to what would ...
Touch Focus Error My problem is similar to the one I just read. When I run the TF setting in front of the TV when it gets to the RED lines it shows one of the lines like a SINE wave or curvy instead ...
...Error 04 - 53. Have already got previous dubbings on this disc with no problem but am now unable to access anything from this disc (as it contained grandchildren activities from Jan 2008 this is ...
Question about PT-56WX53 53" Rear Projection HDTV-Ready Television
56" rear projection won't turn on When "on" button is pressed, no picture, no crackling warmup sound. "on" light indicator flashes 3 times intermittently, Continues to do so. No problems before this. ...
Question about KP-53XBR200 53" Rear Projection Television
When I auto focus I get error 10G Also the green color is drooping and will not line up with the red and blue. I am thinking about buying a green CRT system on Ebay but it is from a kp-61hs10. The ...
Question about PT-51HX43 51" Rear Projection Television
...53" TV model PT-51hx43G. Just got this bad boy back from my ex wife and when i turn it on the power led flashes 3/5 times and goes dim. I have checked the power and control pcb's for cold solder ...
Error/Prot Detected by Device Defective module Result 1 I2C1 2 I2C2 3 I2C3 4 I2C4 5 VIPER 6 5V supply 7 8V6 supply 8 1.2V DC/DC 11 3.3V DC/DC 12 12V supply 14 Supply Class D amplifiers 14 Supply Audio
...module? This error returns after 53 to 86 miles consistently and before all engine readiness tests complete. Car will not pass inspection in this state. Any ideas? Try to clean the mass air flow ...
error was 53 or 58 i think. Please anyone help. Thanks, Bahamas sounds like the lid switch, try depressing switch while the lid is open and machine is on, switch is located just oppsite the tab or pin
Question about HE2 Plus Front Load Washer
...53 y pausa" Good Afternoon Friend, this is Z. I am happy to assist you! An error code E53, relates to the speed control board or the main control board of your washer which can cause it to ...
