picture has red and blue shadows when i push the majic focus button it cycles threw the colors but when it gets to the blue it moves to the far left then stops and a number 4 comes up on the lower ...
Question about PT-53WX53 53" Rear Projection HDTV-Ready Television
...Do you know what could be causing it? Thats the error for convergence failure. You can get the PT53WX53G convergence repair kit at www.tvrepairworld.com the kit contains the parts and CD with ...
...over any ideas code 32 - egr system error. code 53- vehicle anti theft system fault code 54 - fuel pump voltage low suggest that your vehicle anti theft system is causing the no turn over ...
...: http://safemanuals.com/zearchres_3087.php good luck . rate if useful please ! c0b50-53 is stapler unit error. you may have to call a tech to check the stapler motor. it is a hardware error. ...
error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB6.5; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET CLR 1.1.4322; .NET4.0C; .NET4.0E)
Question about KP-53HS30 53" Rear Projection HDTV-Ready Television
tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself. this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I
panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound Hi, 3 times red light flashing is an error code that indicates problem in convergence output section, please check ...
I have a problem with my HDTV 1080i. The model number at the back is PT-53WX54J. It doesn't turn on. It makes few bips when we try to turn it on. Please describe what would be the problem and what ...
...53 appears on the screen - and no buttons work, I can do? This is an error on the main control board. Remove the power and remove the top cover. Do not touch any capacitors within but try and remove ...
Question about SMH8165B Microwave Oven
error codes 53 and 89 I have the same thing for my ac and heating! U can try to reset it or try taking it off and putting it back on . And that doesn't work then call the company and they can help u .
